Fixed bugs and other changes:
7/21/2010
[+] The "Advanced PDF Save Options" dialog may not display the initial default encoding data (however, the data - if defined - will be used by GS-Calc correctly).
7/19/2010
[+] The "Landscape" option is ignored when saving PDF files.
7/8/2010
[+] When selecting entire columns or rows as formula parameters Ctrl must not be pressed. (Should be the opposite.)
[+] If the 2nd or 3rd parameter in the "IF" function is an array/range and if their sizes differ, GS-Calc crashes instead of displaying the "invalid argument value" error code.
[+] The F2 key is not active in the tree view.
[+] Some minor modifications regarding how GS-Calc acts after right-clicking cells and charts.
[+] Automatic text wrapping in the "Cell Comments" dialog.
7/6/2010
[+] Some files saved as PDF by the trial version may cause reporting some problems by Adobe PDF viewers (though the pages are displayed correctly).
[+] When copying and pasting formulas, updated cell references are always increased, even if the copy operation should result in decreasing the row/column reference.
